pcb chip via size question
Sniper2 , 01-05-2025, 10:01 AM
So many chips have a thermal pad and the commandeered footprint has vias in it.If i dont want to use caped and filled vias haw large can i make them?Most often i see 0.2mm in the datasheet i was wandering would 0.25 or 0.3mm be ok? as in not that much solder will drain out of them? Asking since if i am forced to use that small via type for a chip i raise the manufacture cost a lot on some board houses. (and then i am sort of forced to take advantage of that tiny drill in normal vias too)I was thinking of puting some larger vias like 0.3mm drill instead of .2mm.Can anyone tell me please how stuff works in practice or some extra recomandations?
Robert Feranec , 01-05-2025, 11:31 AM
I often use 0.3mm hole under exposed pad, no one reported any problems with it from production
Sniper2 , 01-05-2025, 12:32 PM
Thx
