I Need help.  I tried submitting the OpenREX board for PCB quote and am getting responses which are quite expensive $1000-$3000 for bare board qty 30, with most quotes being in the $3000 range.  Has this design been looked at for production cost (reduction)?  At the moment this board is too expensive to produce.  Here are some of the comments I receive which I don't know how to answer (I'm not a board layout person, yet):
- "Please note, VT-47 is not a stocked material, I've attached a spec sheet for NP-175 which your boards would be constructed on." [Quote $3600 for 30 bare boards]
- "The only difference really is the material. This is quoted on 370HR since we don’t have good impedance numbers for the VT-47 called out in the stack-up.
We also could only get 96 ohms for 100 ohms would that be acceptable?"[Quote $3400 for 30 bare boards]
- "VT-47 is not a material Sunstone or it's partner companies stock and would need to be special ordered. I've attached a material sheet for our in house FR4 material, I would also recommend you review our
stack ups for what we can build in house." [no quote]
https://www.sunstone.com/pcb-manufac.../layer-stackup- "3.74" X 2.756", 10 LAYER, QUOTED WITH 370HR, CLASS 2, .063" THICK, SMALLEST PTH 7.87 MILS, ENIG, ROHS, STANDARD TECHNOLOGY - ARRAYED 2 UP - QUOTED WITHOUT VIA FILL"  [Quote $2,313.00]
