Hi All,    I have done DDR memory calibration for my imx6q custom hardware design using NXP stress tester version 2.9 in ambient temperature and got proper and reliable read,write,dqs gating values for DDR memory. And I updated u-boot configs according to those values as follows.
Design passed all memory tests.
Memory AS4C256M16D3A-12BCN       ============================================
          DDR Stress Test (2.6.0)
          Build: Aug  1 2017, 17:33:25
          NXP Semiconductors.
          Chip ID
  CHIP ID = i.MX6 Dual/Quad (0x63)
  Internal Revision = TO1.2
          Boot Configuration
  SRC_SBMR1(0x020d8004) = 0x18000030
  SRC_SBMR2(0x020d801c) = 0x21000011
  ARM Clock set to 1GHz
          DDR configuration
  BOOT_CFG3[5-4]: 0x00, Single DDR channel.
  DDR type is DDR3
  Data width: 64, bank num: 8
  Row size: 15, col size: 10
  Chip select CSD0 is used
  Density per chip select: 2048MB
  Current Temperature: 26
  DDR Freq: 396 MHz
  ddr_mr1=0x00000004
  Start write leveling calibration...
  running Write level HW calibration
  Write leveling calibration completed, update the following registers in your initialization script
      MMDC_MPWLDECTRL0 ch0 (0x021b080c) = 0x00190022
      MMDC_MPWLDECTRL1 ch0 (0x021b0810) = 0x00250017
      MMDC_MPWLDECTRL0 ch1 (0x021b480c) = 0x0011001C
      MMDC_MPWLDECTRL1 ch1 (0x021b4810) = 0x0010001E
  Write DQS delay result:
     Write DQS0 delay: 34/256 CK
     Write DQS1 delay: 25/256 CK
     Write DQS2 delay: 23/256 CK
     Write DQS3 delay: 37/256 CK
     Write DQS4 delay: 28/256 CK
     Write DQS5 delay: 17/256 CK
     Write DQS6 delay: 30/256 CK
     Write DQS7 delay: 16/256 CK
  Starting DQS gating calibration
  . HC_DEL=0x00000000 result[00]=0x11111111
  . HC_DEL=0x00000001 result[01]=0x11011111
  . HC_DEL=0x00000002 result[02]=0x00000000
  . HC_DEL=0x00000003 result[03]=0x00000000
  . HC_DEL=0x00000004 result[04]=0x11111111
  . HC_DEL=0x00000005 result[05]=0x11111111
  . HC_DEL=0x00000006 result[06]=0x11111111
  . HC_DEL=0x00000007 result[07]=0x11111111
  . HC_DEL=0x00000008 result[08]=0x11111111
  . HC_DEL=0x00000009 result[09]=0x11111111
  . HC_DEL=0x0000000A result[0A]=0x11111111
  . HC_DEL=0x0000000B result[0B]=0x11111111
  . HC_DEL=0x0000000C result[0C]=0x11111111
  . HC_DEL=0x0000000D result[0D]=0x11111111
  DQS HC delay value low1 = 0x02020202, high1=0x03030303
  DQS HC delay value low2 = 0x02020102, high2=0x03030303
  loop ABS offset to get HW_DG_LOW
  . ABS_OFFSET=0x00000000 result[00]=0x11111111
  . ABS_OFFSET=0x00000004 result[01]=0x11011111
  . ABS_OFFSET=0x00000008 result[02]=0x10011111
  . ABS_OFFSET=0x0000000C result[03]=0x10011111
  . ABS_OFFSET=0x00000010 result[04]=0x10011111
  . ABS_OFFSET=0x00000014 result[05]=0x10111111
  . ABS_OFFSET=0x00000018 result[06]=0x10011111
  . ABS_OFFSET=0x0000001C result[07]=0x10111111
  . ABS_OFFSET=0x00000020 result[08]=0x00010111
  . ABS_OFFSET=0x00000024 result[09]=0x00010111
  . ABS_OFFSET=0x00000028 result[0A]=0x00010111
  . ABS_OFFSET=0x0000002C result[0B]=0x00010001
  . ABS_OFFSET=0x00000030 result[0C]=0x00000000
  . ABS_OFFSET=0x00000034 result[0D]=0x00000000
  . ABS_OFFSET=0x00000038 result[0E]=0x00000000
  . ABS_OFFSET=0x0000003C result[0F]=0x00000000
  . ABS_OFFSET=0x00000040 result[10]=0x00000000
  . ABS_OFFSET=0x00000044 result[11]=0x00000000
  . ABS_OFFSET=0x00000048 result[12]=0x00000000
  . ABS_OFFSET=0x0000004C result[13]=0x00000000
  . ABS_OFFSET=0x00000050 result[14]=0x00000000
  . ABS_OFFSET=0x00000054 result[15]=0x00000000
  . ABS_OFFSET=0x00000058 result[16]=0x00000000
  . ABS_OFFSET=0x0000005C result[17]=0x00000000
  . ABS_OFFSET=0x00000060 result[18]=0x00000000
  . ABS_OFFSET=0x00000064 result[19]=0x00000000
  . ABS_OFFSET=0x00000068 result[1A]=0x00000000
  . ABS_OFFSET=0x0000006C result[1B]=0x00000000
  . ABS_OFFSET=0x00000070 result[1C]=0x00000000
  . ABS_OFFSET=0x00000074 result[1D]=0x00000000
  . ABS_OFFSET=0x00000078 result[1E]=0x00000000
  . ABS_OFFSET=0x0000007C result[1F]=0x00000000
  loop ABS offset to get HW_DG_HIGH
  . ABS_OFFSET=0x00000000 result[00]=0x00000000
  . ABS_OFFSET=0x00000004 result[01]=0x00000000
  . ABS_OFFSET=0x00000008 result[02]=0x00000000
  . ABS_OFFSET=0x0000000C result[03]=0x00000000
  . ABS_OFFSET=0x00000010 result[04]=0x00000000
  . ABS_OFFSET=0x00000014 result[05]=0x00000000
  . ABS_OFFSET=0x00000018 result[06]=0x00000000
  . ABS_OFFSET=0x0000001C result[07]=0x00000000
  . ABS_OFFSET=0x00000020 result[08]=0x00000000
  . ABS_OFFSET=0x00000024 result[09]=0x00000000
  . ABS_OFFSET=0x00000028 result[0A]=0x00000000
  . ABS_OFFSET=0x0000002C result[0B]=0x00000000
  . ABS_OFFSET=0x00000040 result[10]=0x01000000
  . ABS_OFFSET=0x00000044 result[11]=0x01000000
  . ABS_OFFSET=0x00000048 result[12]=0x01000000
  . ABS_OFFSET=0x0000004C result[13]=0x01001000
  . ABS_OFFSET=0x00000050 result[14]=0x01001010
  . ABS_OFFSET=0x00000054 result[15]=0x01001110
  . ABS_OFFSET=0x00000058 result[16]=0x01001111
  . ABS_OFFSET=0x0000005C result[17]=0x01001111
  . ABS_OFFSET=0x00000060 result[18]=0x11101111
  . ABS_OFFSET=0x00000064 result[19]=0x11101111
  . ABS_OFFSET=0x00000068 result[1A]=0x11101111
  . ABS_OFFSET=0x0000006C result[1B]=0x11111111
  . ABS_OFFSET=0x00000070 result[1C]=0x11111111
  . ABS_OFFSET=0x00000074 result[1D]=0x11111111
  . ABS_OFFSET=0x00000078 result[1E]=0x11111111
  . ABS_OFFSET=0x0000007C result[1F]=0x11111111
  BYTE 0:
  Start:  HC=0x01 ABS=0x30
  End:  HC=0x03 ABS=0x54
  Mean:  HC=0x02 ABS=0x42
  End-0.5*tCK:  HC=0x02 ABS=0x54
  Final:  HC=0x02 ABS=0x54
  BYTE 1:
  Start:  HC=0x01 ABS=0x2C
  End:  HC=0x03 ABS=0x4C
  Mean:  HC=0x02 ABS=0x3C
  End-0.5*tCK:  HC=0x02 ABS=0x4C
  Final:  HC=0x02 ABS=0x4C
  BYTE 2:
  End:  HC=0x03 ABS=0x50
  Mean:  HC=0x02 ABS=0x3E
  End-0.5*tCK:  HC=0x02 ABS=0x50
  Final:  HC=0x02 ABS=0x50
  BYTE 3:
  Start:  HC=0x01 ABS=0x20
  End:  HC=0x03 ABS=0x48
  Mean:  HC=0x02 ABS=0x34
  End-0.5*tCK:  HC=0x02 ABS=0x48
  Final:  HC=0x02 ABS=0x48
  BYTE 4:
  End:  HC=0x03 ABS=0x68
  Mean:  HC=0x02 ABS=0x4C
  End-0.5*tCK:  HC=0x02 ABS=0x68
  Final:  HC=0x02 ABS=0x68
  BYTE 5:
  Start:  HC=0x00 ABS=0x20
  End:  HC=0x03 ABS=0x5C
  Mean:  HC=0x01 ABS=0x7D
  End-0.5*tCK:  HC=0x02 ABS=0x5C
  Final:  HC=0x02 ABS=0x5C
  BYTE 6:
  Start:  HC=0x01 ABS=0x08
  End:  HC=0x03 ABS=0x3C
  Mean:  HC=0x02 ABS=0x22
  End-0.5*tCK:  HC=0x02 ABS=0x3C
  Final:  HC=0x02 ABS=0x3C
  BYTE 7:
  DQS calibration MMDC0 MPDGCTRL0 = 0x024C0254, MPDGCTRL1 = 0x02480250
  DQS calibration MMDC1 MPDGCTRL0 = 0x025C0268, MPDGCTRL1 = 0x025C023C
  Note: Array result[] holds the DRAM test result of each byte.
        0: test pass.  1: test fail
        4 bits respresent the result of 1 byte.
        result 00000001:byte 0 fail.
        result 00000011:byte 0, 1 fail.
  Starting Read calibration...
  ABS_OFFSET=0x04040404 result[01]=0x11111111
  ABS_OFFSET=0x08080808 result[02]=0x11111111
  ABS_OFFSET=0x0C0C0C0C result[03]=0x11111111
  ABS_OFFSET=0x10101010 result[04]=0x11111011
  ABS_OFFSET=0x14141414 result[05]=0x01111001
  ABS_OFFSET=0x18181818 result[06]=0x00011000
  ABS_OFFSET=0x1C1C1C1C result[07]=0x00010000
  ABS_OFFSET=0x20202020 result[08]=0x00000000
  ABS_OFFSET=0x24242424 result[09]=0x00000000
  ABS_OFFSET=0x28282828 result[0A]=0x00000000
  ABS_OFFSET=0x2C2C2C2C result[0B]=0x00000000
  ABS_OFFSET=0x30303030 result[0C]=0x00000000
  ABS_OFFSET=0x34343434 result[0D]=0x00000000
  ABS_OFFSET=0x38383838 result[0E]=0x00000000
  ABS_OFFSET=0x3C3C3C3C result[0F]=0x00000000
  ABS_OFFSET=0x40404040 result[10]=0x00000000
  ABS_OFFSET=0x44444444 result[11]=0x00000000
  ABS_OFFSET=0x48484848 result[12]=0x00000000
  ABS_OFFSET=0x4C4C4C4C result[13]=0x00000000
  ABS_OFFSET=0x50505050 result[14]=0x00000000
  ABS_OFFSET=0x54545454 result[15]=0x00000000
  ABS_OFFSET=0x58585858 result[16]=0x00000000
  ABS_OFFSET=0x5C5C5C5C result[17]=0x00000000
  ABS_OFFSET=0x60606060 result[18]=0x00000000
  ABS_OFFSET=0x64646464 result[19]=0x00000110
  ABS_OFFSET=0x68686868 result[1A]=0x00001111
  ABS_OFFSET=0x6C6C6C6C result[1B]=0x11001111
  ABS_OFFSET=0x70707070 result[1C]=0x11101111
  ABS_OFFSET=0x74747474 result[1D]=0x11101111
  ABS_OFFSET=0x78787878 result[1E]=0x11111111
  ABS_OFFSET=0x7C7C7C7C result[1F]=0x11111111
  Byte 0: (0x18 - 0x64), middle value:0x3e
  Byte 1: (0x14 - 0x60), middle value:0x3a
  Byte 2: (0x10 - 0x60), middle value:0x38
  Byte 3: (0x1c - 0x64), middle value:0x40
  Byte 4: (0x20 - 0x74), middle value:0x4a
  Byte 5: (0x18 - 0x6c), middle value:0x42
  Byte 6: (0x18 - 0x68), middle value:0x40
  Byte 7: (0x14 - 0x68), middle value:0x3e
  MMDC0 MPRDDLCTL = 0x40383A3E, MMDC1 MPRDDLCTL = 0x3E40424A
  Starting Write calibration...
  ABS_OFFSET=0x08080808 result[02]=0x11111110
  ABS_OFFSET=0x0C0C0C0C result[03]=0x10110010
  ABS_OFFSET=0x10101010 result[04]=0x10110010
  ABS_OFFSET=0x14141414 result[05]=0x10100000
  ABS_OFFSET=0x18181818 result[06]=0x00000000
  ABS_OFFSET=0x1C1C1C1C result[07]=0x00000000
  ABS_OFFSET=0x64646464 result[19]=0x00001000
  ABS_OFFSET=0x68686868 result[1A]=0x00001000
  ABS_OFFSET=0x6C6C6C6C result[1B]=0x00001111
  ABS_OFFSET=0x70707070 result[1C]=0x00001111
  ABS_OFFSET=0x74747474 result[1D]=0x01001111
  ABS_OFFSET=0x78787878 result[1E]=0x01001111
  ABS_OFFSET=0x7C7C7C7C result[1F]=0x11011111
  Byte 0: (0x08 - 0x68), middle value:0x38
  Byte 1: (0x14 - 0x68), middle value:0x3e
  Byte 2: (0x0c - 0x68), middle value:0x3a
  (0x18 - 0x7c), middle value:0x4a
  Byte 6: (0x0c - 0x70), middle value:0x3e
  Byte 7: (0x18 - 0x78), middle value:0x48
  MMDC0 MPWRDLCTL = 0x363A3E38,MMDC1 MPWRDLCTL = 0x483E4A46
     MMDC registers updated from calibration
     Read DQS Gating calibration
     MPDGCTRL0 PHY0 (0x021b083c) = 0x024C0254
     MPDGCTRL1 PHY0 (0x021b0840) = 0x02480250
     MPDGCTRL0 PHY1 (0x021b483c) = 0x025C0268
     MPDGCTRL1 PHY1 (0x021b4840) = 0x025C023C
     Read calibration
     MPRDDLCTL PHY0 (0x021b0848) = 0x40383A3E
     MPRDDLCTL PHY1 (0x021b4848) = 0x3E40424A
     Write calibration
     MPWRDLCTL PHY0 (0x021b0850) = 0x363A3E38
     MPWRDLCTL PHY1 (0x021b4850) = 0x483E4A46
  Success: DDR calibration completed!!!
DDR configaration file
   * Copyright (C) 2013 Boundary Devices
   * SPDX-License-Identifier: GPL-2.0+
   * Refer doc/README.imximage for more details about how-to configure
   * and create imximage boot image
   * The syntax is taken as close as possible with the kwbimage
  /* image version */
  IMAGE_VERSION 2
  /*2GB configarations for Tengri Stack 2 Rev 2
   * Boot Device : one of
   * spi, sd (the board has no nand neither onenand)
  BOOT_FROM      spi
  #define __ASSEMBLY__
  #include <config.h>
  #ifdef CONFIG_SECURE_BOOT
  CSF CONFIG_CSF_SIZE
  #endif
  #include "asm/arch/mx6-ddr.h" // DDR Script I/O settings
  #include "asm/arch/iomux.h"
  #include "asm/arch/crm_regs.h"
  /* Kulunu VTOS Change */
  DATA 4 0x020C4018 0x00260324
  /* IOMUX configuration: DDR DQS signals */
  DATA 4 0x020E05A8 0x00000028
  DATA 4 0x020E05B0 0x00000028
  DATA 4 0x020E0524 0x00000028
  DATA 4 0x020E051C 0x00000028
  DATA 4 0x020E0518 0x00000028
  DATA 4 0x020E050C 0x00000028
  DATA 4 0x020E05B8 0x00000028
  DATA 4 0x020E05C0 0x00000028
  /* IOMUX configuration: DDR DQ signals */
  DATA 4 0x020E05AC 0x00000028
  DATA 4 0x020E05B4 0x00000028
  DATA 4 0x020E0528 0x00000028
  DATA 4 0x020E0520 0x00000028
  DATA 4 0x020E0514 0x00000028
  DATA 4 0x020E0510 0x00000028
  DATA 4 0x020E05BC 0x00000028
  DATA 4 0x020E05C4 0x00000028
  /* IOMUX configuration: DDR control signals */
  DATA 4 0x020E056C 0x00000028
  DATA 4 0x020E0578 0x00000028
  DATA 4 0x020E0588 0x00000028
  DATA 4 0x020E0594 0x00000028
  DATA 4 0x020E057C 0x00000028
  DATA 4 0x020E0590 0x00003000
  DATA 4 0x020E0598 0x00003000
  DATA 4 0x020E058C 0x00000000
  DATA 4 0x020E059C 0x00000028
  DATA 4 0x020E05A0 0x00000028
  /* IOMUX configuration: DDR group control */
  DATA 4 0x020E0784 0x00000028
  DATA 4 0x020E0788 0x00000028
  DATA 4 0x020E0794 0x00000028
  DATA 4 0x020E079C 0x00000028
  DATA 4 0x020E07A0 0x00000028
  DATA 4 0x020E07A4 0x00000028
  DATA 4 0x020E07A8 0x00000028
  DATA 4 0x020E0748 0x00000028
  DATA 4 0x020E074C 0x00000028
  DATA 4 0x020E0750 0x00020000
  DATA 4 0x020E0758 0x00000000
  DATA 4 0x020E0774 0x00020000
  DATA 4 0x020E078C 0x00000028
  DATA 4 0x020E0798 0x000C0000
  /* MMDC: PHY 1 Read Delay Registers */
  DATA 4 0x021B081C 0x33333333
  DATA 4 0x021B0820 0x33333333
  DATA 4 0x021B0824 0x33333333
  DATA 4 0x021B0828 0x33333333
  /* MMDC: PHY 2 Read Delay Registers */
  DATA 4 0x021B481C 0x33333333
  DATA 4 0x021B4820 0x33333333
  DATA 4 0x021B4824 0x33333333
  DATA 4 0x021B4828 0x33333333
  DATA 4 0x021B0018 0x00011740
  /* MMMDC: initialization sequence */
  DATA 4 0x021B001C 0x00008000
  DATA 4 0x021B000C 0x676B5333 //
  DATA 4 0x021B0010 0xB66D8B63
  DATA 4 0x021B0014 0x01FF00DB
  DATA 4 0x021B002C 0x000026d2
  DATA 4 0x021B0030 0x006B1023
  DATA 4 0x021B0008 0x00333040
  DATA 4 0x021B0004 0x0002002D      //new
  DATA 4 0x021B0040 0x00000047
  DATA 4 0x021B0000 0x841A0000
  /* MMDC: write mode registers: 2,3,1,0 */
  DATA 4 0x021B001C 0x02808032
  DATA 4 0x021B001C 0x00008033
  DATA 4 0x021B001C 0x00048031
  DATA 4 0x021B001C 0x15208030
  /* MMDC: Enable ZQ calibration */
  DATA 4 0x021B001C 0x04008040
  DATA 4 0x021B0800 0xa1390003
  DATA 4 0x021B4800 0xa1390003
  DATA 4 0x021B0020 0x00007800
  DATA 4 0x021B0818 0x00022227
  DATA 4 0x021B4818 0x00022227
  /*Read DQS Gating calibration*/
  DATA 4 0x021B083C 0x024C0254
  DATA 4 0x021B0840 0x02480250
  DATA 4 0x021B483C 0x025C0268
  DATA 4 0x021B4840 0x025C023C
  /*Read calibration*/
  DATA 4 0x021B0848 0x40383A3E
  DATA 4 0x021B4848 0x3E40424A
  /*Write calibration*/
  DATA 4 0x021B0850 0x363A3E38
  DATA 4 0x021B4850 0x483E4A46
  /*Write leveling calibration*/
  DATA 4 0x021B080C 0x00190022
  DATA 4 0x021B0810 0x00250017
  DATA 4 0x021B480C 0x0011001C
  DATA 4 0x021B4810 0x0010001E
  DATA 4 0x021B08B8 0x00000800
  DATA 4 0x021B48B8 0x00000800
  DATA 4 0x021B001C 0x00000000
  DATA 4 0x021B0404 0x00011006
  DATA 4 0x021b0004 0x0002556D
  /* set the default clock gate to save power */
  DATA 4, CCM_CCGR0, 0x00C03F3F
  DATA 4, CCM_CCGR1, 0x0030FC03
  DATA 4, CCM_CCGR2, 0x0FFFC000
  DATA 4, CCM_CCGR3, 0x3FF00000
  DATA 4, CCM_CCGR4, 0x00FFF300
  DATA 4, CCM_CCGR5, 0x0F0000C3
  DATA 4, CCM_CCGR6, 0x000003FF
  /* enable AXI cache for VDOA/VPU/IPU */
  DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF
  #ifdef CONFIG_MX6QP
  /* set IPU AXI-id1 Qos=0x1 AXI-id0/2/3 Qos=0x7 */
  DATA 4, MX6_IOMUXC_GPR6, 0x77177717
  DATA 4, MX6_IOMUXC_GPR7, 0x77177717
  #else
  /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */
  DATA 4, MX6_IOMUXC_GPR6, 0x007F007F
  DATA 4, MX6_IOMUXC_GPR7, 0x007F007F
  #endif
   * Setup CCM_CCOSR register as follows:
   * cko1_en  = 1    --> CKO1 enabled
   * cko1_div = 111  --> divide by 8
   * cko1_sel = 1011 --> ahb_clk_root
   * This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz
  DATA 4, CCM_CCOSR, 0x000000fb
System was running properly on the day I calibrated and after few days I'm getting kernel panics.  As well as I have 50 units of this units some units work properly and some are getting kernel panics.  - Any dependency on memory calibration on humidity or moisture ?
- Can you see any fault in my configuration file ?
Regards,  Kulunu.
