Paul van Avesaath , 07-02-2018, 01:01 AM
There is no thermal solution within altium. I can suggest the same as robert because the PDN analyzer gives you some information of were hotspots can be.
but it does not take into account if there are components heating up. so if you want to know if your PCB can sink enough thermal into the pcb with lets say an CPU (with exposed pad) or PSU then it is not possible.
best way I have found is making a mock up  putting in resistors at the key locations (simulating calculated power consumption). and doing temp testing the "old fashion way" either with temp sensors or Flir camera, also if you are using or planning to use airflow as cooling, make sure it is present in the "simulation"
it really gives a good idea on how the end result will look without spending a crazy amount for thermal analasys by third party companies.
