@ican7, I understand your question, but by providing you the straight answer I would not really help you
 So, what you can for example do:
- Find datasheet of the chip (ADM489A)
- In the datasheet, check out power voltage, input voltage and output voltage of the chip for the LOGIC
- Find datasheet of your microcontroller. Check out power voltage, input voltage and output voltage for the IO pins
- Check out if pull ups / downs are not required
I would also recommend you:
- order the kit, power it up, measure the levels on the pins
- connect the pins with your microcontroller board and see if everything works oki
