Some section ground trace running in between high speed differential pair to avoid the cross talk.
- did you include these GND tracks between pairs when you calculated impedance? also, I believe, if you use this kind of technique, you may need to place VIAs in more places, not just at the beginning and end.
1.cross talk able to meet to provide proper spacing between differential pair 2W spacing .
- bring the sold ground plane under the diff pairs close to them, that will help to eliminate crosstalk. Also, please keep in mind, when you see a recommendation such 2W these are usually done based on specific impedance. this video may help:
https://youtu.be/Bu4MirknEvoSo what is the major role for ground plane in high speed differential signal ?. or does differential pair need ground plane ? because one signal is reference for another signal .c
an you explain short answer for this query.( i red so many document. little bit confusion. ).
- I have the same question what @Paul van Avesaath asked: How did you calculate impedance if you don't have a reference plane?
Also, don't forget. In some cases / interfaces, differential pairs are just two single ended tracks with opposite signals running through them => e.g. even when routing these differential pairs, each track in pair needs to meet specific single ended requirements, for example they have to be routed by 50OHM impedance.
