Blind VIA - you do not drill through the whole PCB. This is definition from Wiki:
IPC standards [1][2] define microvias as blind or buried vias with a diameter equal to or less than 150 μm For more detailed answer you can google some stuff, for example:
https://en.wikipedia.org/wiki/MicroviaIn reality, uVIA is usually Blind VIA, as normally to drill 150um hole you can not use material thicker than 150um (VIA ratio for Blind VIA is usually 1:1, it means, you can not drill deeper than is the hole diameter because you would not be able to manufacture it)
