mulfycrowh , 05-20-2022, 09:44 AM
Hi everyone,
I am working on a motherboard design.
I set it up with 8 layers (Signal 1, GND, Signal 2, Power 1, Power 2, Signal 3, GND, Signal 4).
I have about 150 differential pairs.
Among these 150 differential pairs, at present time, about  90 pairs are routed.
Still remaining are pairs between CPU and GPU, all pairs involving SSDs, Wi-Fi, LAN ...
I am facing trouble to route the remaining pairs.
I use Signal 2 and Signal 3.
The true question now is should I use 10 layers ?
As an example, I requested an instant quote by PCBWay.
For a PCB - 200mm X 300mm, I got the price, including shipping, of $500 for 5 samples with 8 layers and $826 for samples with 10 layers.
So we have to add 65% for 10 layers ?
Does it seem coherent ?
Did you already manufacture 10 layers PCBs ? What was the budget ?
If you had to add 2 layers, where would you insert them ? Between GND and Signal 2 and Signal 3 and GND ?
Would you insert GND planes ? In that case we would have 12 layers...
Thanks a lot.
