Tomsiik , 03-24-2022, 01:07 PM
thanks to Robert's episode about crosstalk, I've decided to try an experiment on my own.
I've designed PCB for testing crosstalk, there are some traces like aggressor/victim with multiple gap cases.
Stackup up of PCB is standard JLC7628 from JLCPCB manufacturer.
The first idea is to compare against software calculator "PCB Toolkit" with my test PCB.
I've got calculated coupled voltage 1.65V, I wanted to measure this voltage on my test PCB.
There is a test connection. All oscilloscope channels have 50Ohm impedance. Test signal has 10Mhz and approximately 5ns edges.
On scope, I've got 116mV pk-pk as NEXT and just 15mV pk-pk as FEXT.
I just want to see a correlation of my measured result with the calculated coupled voltage. I can't imagine what coupled voltage means, how to measure it that I can get the notion.
Is there anyone who can explain what I calculated and what I measured?
Because calculated 1.65V looks very horrible but measured 116mV pk-pk is correct in my opinion...
btw. I've tried to change impedance in the oscilloscope channels but the measured pk-pk voltage is still under the 200mV.
