Good morning everyone!
I'm new to this forum. Let me introduce myself. I'm an electronic engineer who works as R&D Engineer for a small company. I'm mainly involved on writing firmware and developing algorithms for microcontrollers. Sometimes I route Pcb Boards for microcontroller applications (by OrCad Pcb Designer).
This time I'm involved in a PCB problem with a microprocessor (an 8 bit old one operating with a crystal of 26.045 MHz). My goal is to find a way to make this specific microprocessor board work. Let me explain better:
bout 2 years ago, in order to save money, my company decided to merge two complementary boards (both 4 layers) - which work fine since more than 20 years - into one. The new merged board was developed by a third part company. It has the same hardware than the two previous boards. After some basic positive tests and putting it in production we received, almost immediately, lots of negative feedbacks from the field. The board suddenly stops working due to unexpected random (and unknown) event. After other specific tests It seems that the bad event is caused by noise coming from outside the board and I'm strongly worried about an EMI problem. Excluding a problem on the firmware (it is the same than the two boards that works well since years) I decided to going back and look at pcb tracks.
This is a 4 layer board and I cannot identify a separation between Ground, Power and signals, maybe because of the high number of signals (address bus, data bus and many I/Os) and high density of components.
I have a lot of question obvously, but
I'm asking if someone can help me to find a book or a good course on the topic so that I can orient myself to route well the board for this specific application (data buses, address buses...)
Watching at some of Robert videos I saw that maybe 4 layers is not a good idea for this board (6 would be a better choice), so I'm deciding to route again the board with 6 layers instead of 4.
a) Can be the following 6 layers order considered a good choice (Rick Hartley on
https://www.youtube.com/watch?v=52fxuRGifLU&t=2891s)?- sgn/Power
- Ground
- sgn/Power
- Ground
- sgn/Power
- Ground
b) I understand that, in this distribution, every time a signal "jumps" from 1) to 5) or viceversa I need to put a Ground Via nearby in order to guarantee a good return path for displacement currents.
Am I right?
Every comment or idea for a better routing is really appreciated
I'll share with you any pcb image if necessary without any problem
P.S.
I know that the processor is an old one, maybe a good 32 microcontroller could do the job, but the company decided to still keep it for a while.
Thank you a lot
Marco
