Originally posted by
robertferanec- so, you are using the board everything is running fine and then suddenly after days of weeks it crashes or freezes or reboot (what exactly is happening)?
Crashes, because the PC can not mount the Serial COM, but can see that there is anything at USB line, but can not mount.
I have 3 more systems like this, but only on at one that problem appears. I replaced my board, PC, USB cable, Power adapter and I am having the same problem.
The fridge is a really big problem. I measured the AC line and every time the motor Switch on/off changes the VPP to a lower value.
I am using a ferrite on USB cable, but I am getting the same problem.
I made a test. If I switch off my board, with all big capacitors and capacitors of power adapter, my board remains, near 2 seconds, working. But If I power on my board again with a delay near this 2 seconds after switch off, my PC can not recognize the USB Serial Converter.
I am using Net-ties to connect grounds, because I have another circuit to control 12V solenoids. But I soldered a  jumper o have a better connection between grounds and the problem remains.
​Thank you Robert!
