Custom board design based on iMX7D
kahlenberg , 03-21-2019, 07:11 AM
I want to design a board for iMX7D (MCIMX7D7DVM10SD) processor. I want to use total 2GB Mobile LPDDR3 SDRAM. I want to use LPDDR3 from Micron (MT52L256M32D1PF or MT52L512M32D2PF or MT52L1G32D4PG).
There are 3 different configurations for DRAM (1 Gig x 32, 512 Meg x 32, 256 Meg x 32) and I didn't understand well.
Does the configuration 512 Meg x 32 mean that 2GB of total memory on one chip with 2 die? Can I use this chip and have 2GigaByte of memory?
I also don't understand how I connect memory chip and processor:
The memory chip has no BA (Bank Addres), CAS (Column Address Strobe), RAS (Row Address Strobe), WE (write enable), RESET balls. Shall I leave those balls of processors just floating?
The memory chip has only 10 address lines. Would other balls (DRAM_ADDR11 to DRAM_ADDR15) of processor be floating?
The memory chip has only one ODT input. The processor has two ODTs. Shall I connect only ODT0 of processor to chip?
Thanks.
mairomaster , 03-22-2019, 07:32 AM
Depending on your appliacation bandiwdth requirement and if the processor is happy, you might be able to get away with a single channel (1 chip). The most common configuration is using 2 chips though, since this gives you twice the bandwith.
Connect whichever signals you need and leave the rest floating.
kahlenberg , 03-22-2019, 08:07 AM
Thanks for answer.
The processor MCIMX7D7DVM10SD has 32 bit of DRAM_DATA signals. It means I can not increase bandwidth more thane 32 bit.
robertferanec , 03-25-2019, 11:35 AM
Can you attach screenshots from the datasheet? The datasheets are locked - at least show the first page and the package with pins.
Usually memory chips follow some standard - the footprint is same / compatible between memory chips. It looks to me unusual that chips would not have these signals - but I have not seen iMX7 reference design.
3 different configurations for DRAM (1 Gig x 32, 512 Meg x 32, 256 Meg x 32)"
- these are not configuration, these are just different memory sizes ... x 32 is usually size of data bus.
- for 2 die chips you will find two chip selects in the pins
PS: If you are not sure about memory interface, I highly recommend you to use same memory connection as they have it on reference board.
