Clarification on PCB Routing, EMI and 6 kV Surge Performance – Isolated DC-DC Input Stage
Anoop Varma m , 01-22-2026, 10:02 AM
Dear teamWe have designed an isolated –48 V DC-DC power input stage and would like your guidance on the PCB routing approach with respect to EMI performance and surge immunity.System Overview• Input supply: –48 V DC• DC-DC converters:• –48 V to +48 V (isolated)• –48 V to +12 V (isolated)• Maximum input current: 20 A• PCB: 14-layer stack-up, compact board sizeRouting Strategy• From input to filter output:• LINE and RTN are routed on the same layer• Traces are maintained 2 mm clearanceFrom Filter output to DC-DC modules:• 7 layers used for LINE and 7 layers for RTN• Layer sequence arranged as RTN / LINE / RTN / LINE• Via stitching provided near DC-DC module input through-hole pins for current sharingStack-up and Copper Details• Dielectric thickness between adjacent layers: 0.153 mm• Copper thickness:• Top and bottom layers: 1 oz• Inner layers: 0.5 ozIsolation and Earth Clearance• Isolation of Earth and primary are kept separate• Primary to earth clearance on top layer: 2 mm• Primary to earth clearance on inner layers: 0.5 mmClarifications Required• Is this routing approach effective for differential-mode noise reduction?• Does the multi-layer LINE/RTN structure help in controlling common-mode noise?• Are the isolation clearances sufficient for 6 kV surge immunity?• Is the via stitching near DC-DC input help for EMI ?• Is this approach suitable for meeting CISPR 32 Class A requirements?• Could you suggest the standard routing procedure for the earth connection and the primary isolated power supply input?• Could you suggest the standard routing procedure for the earth connection and the primary isolated power supply input?Your guidance on the above points would be very helpful.
QDrives , 01-22-2026, 11:48 PM
Do note that both your picture and text are not very clear to me, but here goes...1) "*Is this routing approach effective for differential-mode noise reduction?*"Hardly2) "*Does the multi-layer LINE/RTN structure help in controlling common-mode noise?*"No3) "*Are the isolation clearances sufficient for 6 kV surge immunity?*"No, check IEC 60950 or IEC 606644) "*Is the via stitching near DC-DC input help for EMI ?*"I do not see how compared to needing it for current sharing.5) "*Is this approach suitable for meeting CISPR 32 Class A requirements?*"That depends on many other things as well.6) "*Could you suggest the standard routing procedure for the earth connection and the primary isolated power supply input?*"No. Much more information is required. And that would turn it into consultancy...
