replace altium pcb component with my library component
Bitu , 01-22-2025, 04:55 PM
how can i replace altium pcb component with my library component without change his location in PCB
QDrives , 01-22-2025, 04:59 PM
Select the componentIn the properties panel, in the footprint section, click on the three dots next to the footprint nameselect the footprint you want.
QDrives , 01-22-2025, 05:00 PM
But also make sure that you schematic symbol has the correct footprint associated with it.
Bitu , 01-22-2025, 05:30 PM
Ok but I want to change 100 component i think it's lengthy for me to change 1 by 1
Bitu , 01-22-2025, 06:23 PM
What is the meaning of this modify (3 system parameters) what change in pcb after this modification @QDrives
QDrives , 01-22-2025, 07:29 PM
I think that with "system parameters" are like comment, description, type, designator, etc. However, I do not recall having seen it.It could also be a wrong text and that it should simply be 3 parameters, then they are the parameters you add manually.Lastly, seeing the text "vault" there too, it could be that the (user) parameters in the vault are called "system" parameters, which, in my opinion, is incorrect.
QDrives , 01-22-2025, 07:32 PM
To change multiple footprints.Right click on a component and select - Find similar objects.Set the footprint to "SAME"Make sure "clear existing" and "Select match" are checked.Click ok.Follow the rest of the two steps as decribed above
Bitu , 01-22-2025, 07:38 PM
Okay, thank you. I will try this, and I have one more question
Bitu , 01-22-2025, 07:44 PM
@QDrives I downloaded a radar PCB for learning purposes and made some minor changes to it. However, when I run the DRC, I encountered an error, and I’m unable to understand the cause of it. Can you help me understand this error
QDrives , 01-22-2025, 07:48 PM
It is that a component should be inside or outside of a room.I am yet to think of a useful reason to have this rule.Usually I select a component that definitely does not need to be in the room.
Bitu , 01-22-2025, 07:54 PM
@QDrives I want to understand the concept of this room. Can you recommend something to me? How I create this typ of room
QDrives , 01-22-2025, 08:09 PM
How to create a room:- Design / Rooms / Place .... roomDefinition of room is as shown here.
