JohnsonMiller , 08-05-2017, 01:33 AM
Hello Everyone,
Attached is a miniUSB connector, it comes with 4 pads S1, S2, S3, and S4, as you know these pads are connected to each other through metallic body. Regarding to this connector I got 2 questions:
1- Is it correct to connect those pads to GND or any net on board? or we should leave them alone?
2- Connected those pads to GND, you see bending lines which shows connection detected by Altium; however only one pad is connected to GND while three remaining is left floating. When I ask for DRC check, there is no error or warning! I was expecting at least three connection errors. I went through detail of component in SCH and PCB library, but found no clue! Any comment about this behavior?
BR,
