WhoKnewKnows , 07-11-2021, 08:41 AM
In 2D view,. I use transparency settings to fade the silkscreen layers. Otherwise they're a bit too bright and distracting. I use this a little bit on copper layers. This creates a sort of stained glass effect, so an object on one layer doesn't entirely obscure objects on other layers.
I can right click on the layer name tabs at the bottom of the workspace and select highlight to highlight that entire layer.
You can also use the Find similar objects function to build a query that will isolate a certain group of objects which can be revealed to you by masking or highlighting, etc.
