About issue with Polygon Pour
mulfycrowh , 02-07-2021, 08:28 AM
Hi everyone,
I have created a polygon between 2 pads with same net name.
The polygon net is set to the same net name.
I cannot pour the polygon.
Any idea?
Thanks.
AD19.
mulfycrowh , 02-07-2021, 01:12 PM
I made it using Polygon Solid.
Why does it not run with Polygon Pour?
WhoKnewKnows , 02-07-2021, 04:08 PM
This often happens to me.  There are a variety of settings.  Check that pour over all same-net objects is selected? If the polygon is small, make sure the threshold for eliminating parts of the polygon below a certain area is set appropriately.  Try connecting the pads with a track and see if Altium generates an error.  If it allows the two pads to be connected with a track without error, it should allow a polygon pour to connect them too.
robertferanec , 02-08-2021, 01:20 AM
As @WhoKnewKnows is pointing out, that polygon may be too small. Try to uncheck "Remove islands less than the area" -> "In Area" or change the number there.
