Altium 19 Flex-Rigid PCB Design
Dotraki54 , 04-01-2019, 10:49 PM
I draw the PCB which including Rigid and Flex design. But I encountred  a problem that is not drawing rounded flex PCB region using the define split line inside the Rigid PCB region. I am also comminication with Altium distrubutor in Turkey but they don’t find a solution for this problem.I believe that altium has no any tools to define rounded flex region.
Regards,
robertferanec , 04-02-2019, 12:19 AM
Oh, I also noticed limitations in Altium and FLEX (e.g. I have not found a way to properly bend FLEX which is inside of PCB, I have not found a way how to define stiffener in stackup and show stiffener in 3D model, etc.). When I was playing with FLEX, I only remember using lines to define regions ... I used "Define Split Line" and I am not really sure if it is possible to use circle.
Dotraki54 , 04-02-2019, 01:33 AM
Yes I get it.So we should contact to produce such a Rigid-Flex PCB before design it. And I guess that wasn't used like this complex design often because even altium doesnt think about that
