USB5744 Hub design - polarity swapping
MLc , 09-10-2023, 12:33 PM
Hello, I designed USB hub with USB5744. My hub working but I think that it is working only in USB2.0 speed when I testing speeds.
I am confused about TX, RX polarity swapping. If I didn't do a mistake...
I don't use any custom configuration via SPI flash memory or SMBUS.
I swap polarity of the RX line only on the upstream USB connector. Could I have done it? Could I swap only RX lines and TX lines remained unchanged?
Thank you,
Martin
MLc , 09-12-2023, 12:49 AM
EDIT: I solved the problem. There was problem with my USB C-C cable.
Admin you can delete this post...
