Bus routeing
Sniper2 , 02-13-2024, 04:00 PM
So how do i route a multi trace buss in a way that allows me to keep a constant trace clearance, initially i routed it with interactive trace router then i moved it a bit.
Is there a way to rearrange it a bit so that trace spacing is more or less the same ?
Robert Feranec , 02-13-2024, 06:39 PM
i usually route these track wider and close to each other, but once finished I just change the track width to normal - means clearance is then bigger and consistent between tracks
Sniper2 , 02-13-2024, 08:31 PM
hmm in my case i allready did route the, across the board and there are a few places where this method will maybe not work
Sniper2 , 02-13-2024, 08:32 PM
is there a normal way when you do a 45deg angle on a pus to have them autospace furthemr apart then formal and then do what u proposed?
QDrives , 02-13-2024, 10:15 PM
Does the "Gloss and retrace" feature work for you?
Robert Feranec , 02-14-2024, 05:21 AM
I have never used autospace
Roomi#0787 , 02-14-2024, 10:58 AM
Design rules will be your best friend in this respect !
Sniper2 , 02-14-2024, 02:07 PM
What feature? I'll Google and try , thx
Sniper2 , 02-14-2024, 02:12 PM
Can you assign multiple classes to a net?
QDrives , 02-14-2024, 09:38 PM
Yes you can.
Sniper2 , 02-14-2024, 09:43 PM
interesting
Sniper2 , 02-14-2024, 09:44 PM
hmm then i need to gigure out some rules and a priority
Sniper2 , 02-15-2024, 06:49 PM
didnt work
